Results 1 to 4 of 4
Thread: Lt 230 cover plate
    Jul 2007
    jan juc
    Lt 230 cover plate
    How do you remove the lower cover plate on Lt 230 that has be siliconed in place have tried a blade but can't get the blade between the cover and the transfer case and dont want to wreck the surfaces
    Jul 2008
    Ballarat, Victoria
    maybe try a block of wood and a hammer, to shift it slightly to break the seal, the wood wont harm the aluminium casing
    Jul 2009
    Lake Macquarie NSW
    I used a small screwdriver to pry it loose. No damage, if you do damage it, just dress up with a file, all metal particals will fall down anyway but it is highly unlikely you will damage this if you are careful.
    Regards Robbo.
    Jun 2008
    Drouin East, Vic
    A few sharp taps sideways with a hammer +/- block of wood. They do love to leak so I avoid gouging the surface.
