Results 1 to 10 of 14
Thread: Auto tranny cooler
    Aug 2008
    Deception Bay
    Auto tranny cooler
    One for the knowledgeable gurus. Been thinking about using an air conditioner evaporator [the one at the front of the radiator] as an oil cooler for the aoto tranny. My thoughts are that it would/should be large enough to provide adequate cooling when doing heavy work. My concerns are that not enough oil flow, thus causing overheating in the tranny, and alternatively too much cooling therefore tranny not at optium temperature. A good idea or not? Thanks, Bob
    Crafers West South Australia
    An a/c condenser should easily do the flow and pressure. Overcooling? You could arrange a temp gauge/monitor in the trans and bypass the cooler with a solenoid valve when it's running cold.
    Goolwa SA - but top ender forever
    I've been wondering what would be the best way to go - P38 cooler to expensive, aftermarket coolers to small.
    Bob thats a brilliant idea they are cheap and would work a treat
    Avoca Beach
    The pipe should be run through the radiator first so that it is not overcooled.
    However I wonder if you are not killing an ant with a sledgehammer as if you use synthetic oil it can withstand heat without breakdown.
    I guess if you are towing a BIG van it could be useful, but mine has never worried with my 600KG camper even in 40+.
    Regards Philip A
    Apr 2007
    Newcastle NSW
    Philip
    An observation that may / may not be helpful.
    I installed a P38 cooler on my auto after it imploded a couple of years ago, never had an overheating problem since, including towing our camper and lots of low range and high range sand 4wding.
    To my point though, we have just recently been upgrading our camper (ie two deep cycle batteries and running 12V and 240V circuits, and a toolbox for the a frame) so I took it to a weighbridge to get weighed (are you sitting down?). The trailer with camper top, internal drawers, kitchen and basically packed ready to go except for gas, water and kids bikes came in at 1080kg.
    Incidentally, it also measured a 120kg downball weight and the Disco came in at 2230kg (with a full fuel tank, but precious little else).
    Goldey
    Just arrived: 2012 D4 3.0 HSE, the journey begins again ;-).
    Gone: 98 Disco 300tdi Auto, and some extras
    East-South-East Girt-By-Sea
    1.20 MB
    4 Tonne trailer, ZF auto and Mt Victoria, gee I wish I had a bigger trans cooler.
    However what I would suggest, before anything else is to install some form of external monitoring, like a temp sensor and guage. This way you can see if the trans fluid temp is getting up, before it is a problem and drive accordingly.
    My solution (although I haven't fitted it yet) is to merely run a second of the same element used in the RRc and early Discos and I have doubled the cooling.
    May 2009
    Tatura, Vic
    I did this on an old Holden years ago and it worked well. I had converted it from manual to auto and instead of getting a new radiator I used an air con condenser.
    Dave.
    99.87 MB
    Quote Originally Posted by bob h View Post
    I'm not sure that an AC unit would be rated for 120psi or so.
    I've been there, tried that and spent it all - ZF's run significantly more line pressure during lockup than other autos.
    I wouldnt fit a regular ATF or AC cooler. I'd go straight to an ATF cooler with pirtek type multi-barbed pressure fittings or not bother at all. All of the ATF coolers that LR use on the ZF's have pressure fittings rather than the normal slip on or single barb fittings.
    Slunnie
    Yep, and run them parallel, not series. Will drop the flowrate and increase the cooling efficiency.
    Either that or look at an Eaton 18025 cooler used on Roadranger gearboxes.
    Andrew
    AC pressures regularly top 200psi. If you can adapt suitable hose fittings to a multi-path condenser I can't see why it wouldn't work. Proper crimped AC hose fittings should do it providing your cooler hose is compatible.
