27th August 2010, 04:47 PM
2005 TDV6 fuel filter replacement
Hi Forumites,
I have a 2005 TDV6 D3 and I want to change the fuel filter, I've got all the information about changing the clamps on top of the filter from the GTR site. After changing the filter the procedure talks about bleeding the fuel system. I don't have the special tool that connects to the bleed valve is there any other options, how do others do this?
I suspect not everyone has the special tool but manages to change the filter without breaking the fuel pump which seems to be the consequence of not bleeding the system. Any constructive comments welcomed
27th August 2010, 04:51 PM
easy gob,, change filter, then just put the key to ing2 for about a min,, do this about 5-6 times,, the fuel pump bleeds its self,
but do not put the pipes on round the wrong way
been there done that, wondering why its starts then stops
27th August 2010, 05:21 PM
I used the same procedure when i ran out of fuel. Worked a treat!
27th August 2010, 06:01 PM
#4
Hi Stig0000,
Filter changed, used the method you described worked a treat, even managed to get the hoses the right way round, didn't stop when I started it. Thanks for the prompt assistance.
29th August 2010, 10:07 PM
#5
Does anyone know what the procedure is for a 3.0 TDi Discovery 4? Can't exactly turn the key to a specific position and I suspect there are a few more quirks (as the D4 still has some of that loveable British DNA).
29th August 2010, 10:30 PM
#6
Its the same deal on d4 just put the ing to 2
30th August 2010, 07:59 PM
#7
Dingmark Jim,
To turn igntion on only have key in vehicle & push/hold the start button until the dash lights up without putting your foot on the brake.
Thats how you turn on the ignition only.
Cheers.
31st August 2010, 07:32 PM
#8
. I thought pushing "Start/Stop" without the brake depressed might do it, but wanted to make sure before I found myself somewhere remote with a dirty filter!
