Results 1 to 8 of 8
Thread: how to - radiator out ?
    eileen Guest
    does anyone know if there is a way to remove the radiator on my 2003 disco TD5 without removing the cooler in front of it ? The cooler seems to sit in mountings on the rad but I have not got enough free play to get the rad out, Im pretty sure I have all the fixings out, have the fan off etc..
    If you take the fan off and there is plenty of room to take the radiator out or to lean it back and remove the intercooler. The intercooler brackets are removed from behind the grill.
    Dec 2008
    Beechboro Perth
    You should be able to leave the cooler bolted to the radiator & lift them out as a unit, but theres a lot of brackets to remove.
    where in perth are you?.
    Roger
    Thinking more on this and it's all from memory ... when I replaced the intercooler in my 03MY D2 I had to take the horns off and from memory the headlight pods to get to brackets on the radiator and the intercooler. I think the horns covered the intercooler brackets, but I have a sneaky suspicion that some where behind all of that on at least one side was a radiator bracket. Pretty sure it was all covered in RAVE CD.
    Williams West Aust
    Quote Originally Posted by dmdigital View Post
    Grille out/Horns out on the early D2 to get at the intercooler mounts,dont think I had the headlights out.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    When we did Stuuu's D2 we didn't need to take the headlights out. I'm pretty sure I had to on at least the driver's side on my 03MY. Not that it is to hard as they are pod units and it is just 3 screws.
    eileen Guest
    done it, like Andy said grille, horns etc, thanks guys
    Oct 2006
    kinross, Perth, WA
    Hi Mate
    How did you go with the water usage issue? and temp fluctuations? solved it yet or still chasing?
    Steve
