Page 1 of 9 123 ... LastLast
Results 1 to 10 of 86
Thread: Red VS Green Coolant again!!!
    Williams West Aust
    Yet another coolant thread.
    BlackBetty has just been filled with GREEN coolant!!!!
    Im told it meets Landrover Specs,and is specified by Penrite for the TD5.
    It has this coolant in it. http://www.penriteoil.com.au/pis_pdf...JAN%202010.pdf
    Penrites website say they dont do an OAT coolant at present but may do so in the near future.
    I wasnt keen on it going into the Defender so I asked that the coolant not be changed today.
    In the next few weeks a new radiator/waterpump/thermostat and intercooler so I can rid the Penrite if the "Brains Trust" have the same gut feeling I have.
    Up til now Ive been using Nulon OAT coolant at a pretty strong brew since owning the D2(6 years),Ive changed it 3 times not for KMs,more peace of mind.
    An observation today,BlackBetty ran SIGNIFICANTLY cooler than normal in the same conditions on the same hwy.Normaly the temp is 94/96 deg up to 99/100 deg on the last big hill before home.Today 87/88 deg peaking at 92 on the last big hill.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    ACT
    I spoke to an old campaigner at Natrad last week - he was very much against ethylene glycol and OAT/HOAT. Reckoned that they just cause metal corrosion, rubber deterioration and therefore leaking problems. Even though I'm in Canberra, all this guy uses in cooling systems in all the vehicles they service is their own Natra Radiator Conditioner (112g/l Triethanolamine) - they don't recommend anything else unless you hit the snow. This guys been around a long time, so you reckon they would know about it if people had problems with coolant freezing. My Disco gets left outside, and even on a -3 night, the engine bay is still +3 (and water probably warmer still as it is a temperature "buffer" more so than air temp), even if vehicle hasn't been driven that day (it is in the sun during the day).
    Always looking for creative new ways to get bogged... :whistling:
    76 RR...sold coz fuel was expensive at 70c/l :eek:
    93 200 Tdi Disco...old faithful...sold to make way for...
    99 Td5 Disco ACE...nice drive...hopefully reliable...
    Dec 2008
    Riverton W.A.
    Hi Andy,
    The stuff I use comes from Coz at Barbagello's in Ozi Park. It is made by Castrol and is called Radicool Coolant.
    Contains :- 32% Ethelene Glycol
    10ppm Denatonium Benzoate
    also contains a Bittering agent [what ever that is]
    Exceeds AINZS 2108.1 and most international standards.
    Mix 50/50 with distilled water
    Seems to be ok - no problems as yet. Did look at Penrite, Dunno.
    Tony
    here
    Running a stronger brew will run hotter temps. Is the GREEN running the same brew ratios?
    Nothing beats plain water for heat transfer.
    Apr 2010
    South East Queensland near the sea...
    Maybe the bittering agent is make it unpalatable. After all it is highly poisonous if ingested. There was a case in Europe a while back where some unscrupulous wine makers were adding anti freeze to wine to make it sweeter. Needless to say some people died.
    May 2003
    On The Road
    Hey Andy!
    once again our paths cross
    When the shop put the new rocker gaskets in they put in green coolant, I asked the question and the owner said it was organic and the reason he changed brands,, he then went out back to check and came back a bit concerned that the latest packaging didnt have organic on the label anymore.
    anyone in the trade know about "Guardian" coolant??
    Yass NSW
    THat's one of the questions I have for the guys who just did my engine install.
    All I know right now is they filled it with green coolant. As for what specs I don't know but at least it's all new so shouldn't be a case of mixed.
    Avoca Beach
    Conventional antifreeze is formulated with inhibitors composed of neutralized inorganic acids, such as phosphates and silicates, to protect a cooling system against rust and corrosion. Over time, however, inorganic inhibitors deplete and may no longer provide maximum cooling system protection. This is why it is generally recommended that conventional coolants be changed every 2 years or 24,000 miles.
    In contrast, OAT coolants are formulated with neutralized organic acids to form a highly effective corrosion inhibitor system that provides maximum cooling system protection. Organic inhibitors do not deplete as quickly as the inorganic inhibitors used in conventional coolants. This is why properly formulated OAT coolants typically provide up to 150,000 miles or 5 years of cooling system protection between service intervals. The superior OAT formula in PEAK Global LifeTime uniquely provides a LifeTime of cooling system protection - for as long as you own your vehicle.
    back to top
    From Autoexpert site.
    So it appears the advantage of OAT is longer life, and reduced service costs.
    Honda do not recommend change for 10years in my Jazz so it must be good stuff.
    Regard sPhilip A
    ACT
    Honda will no doubt be more than happy to sell you a new radiator, water pump etc in 5 years time...
    Safety Bay
    Quote Originally Posted by feraldisco View Post
    Couldn't agree more.After many a year looking after mobile machinery no one will convince me that OAT is good coolant,also don't ever run coolant at a higher than 50/50 ratio,more coolant means less heat transfer. Pat
