Thread: clutch cover plates
    adelaide sa
    clutch cover plates
    Hi all. can any body supply photo's of the,front of the bulkhead, just below the rubber bung,as i have plenty of spare holes to fill in, it is a 2a lwb maybe 67 and its a 6 cylinder bulk head too, any photos would be great, i think the aluminuim plates are missing from there, not sure what they should be
    thanks Andrew
    Last edited by sykes1; 30th August 2010 at 03:29 PM. Reason: wrong part discription
    JDNSW's Avatar
    Not sure what you are referring to. In the Landrover 2a workshop manual, the clutch cover is what I would refer to as the pressure plate, but I don't think this is what you are after.
    If you mean what blocks the holes in the bell housing - the one on top is blocked by the mounting bracket for the gear lever, the one on the left has a rubber grommet, and the one on the right has a rubber grommet that the clutch shaft goes through.
    Or do you mean the floor panels?
    adelaide sa
    the panel on the bulk head, my memory is going ha ha, below the rubber bung
    Oct 2003
    Godwin Beach Qld
    G'day Sykes1
    The panel you are refering to is the clutch housing cover panel or the rear engine cover housing, also known as the gearbox front cover housing
    Feb 2009
    Warrimoo, Blue Mountains, NSW
    I think Andrew might be referring to the holes in the bulkhead where the hand throttle pokes through. If the hand throttle mounting plate is missing, there's a rectangular hole left over.
    I've attached a photo, where the hand throttle hole has a cover plate over it. And is the rubber bung you're referring to the grommet for the speedo cable?
    Peter
