 Originally Posted by
Bundalene
				Use your hard earned and spend it on a holiday with your Defender and then figure out what is missing. Everyone has their own priorities.
The reason why you have tubes could be because of the wheels dont have the lipped safety seal and are not able to accept tubeless tyres, so replacement wheels such as Series1 Disco mags or steel wheels may be on your shopping list. The steel wheels can also be offset to improve your stability and turning circle.
Do you have a fridge? Dual batteries would then be an advantage.
Long range fuel tanks / water tank, if extended trips are your thing.
Maxis and diff locks, under guarding if the extreme 4wding is your preference.
Erich
