Results 1 to 6 of 6
Thread: Elec Window Issue RRC
    I have a RRC and the passenger elec lock and window have suddenly decided not to work - they were intermittent for a while.
    Any suggestions of how to test what to look for?
    Can I by pass the controls and apply 12 volts to somewhere to test that not the motor?
    All suggestions welcome.
    SKiboy
    89 Orange Rangie UTE - our play thing - sadly now sold
    75 Rangie/Series/Hybrid/LS3 - Bumblebee with a sting!!!!
    2018 RRS - The new touring vehicle - replaces 2012 RRS
    Kootingal
    probably not much help but there was a post here recently about a dry joint problem in the computer of a D1 electric window of which they thought the RRC was similar
    Adelaide - Torrens Park
    Quite possibly a switch fault. I had to rebuild / clean my window switches after I bought my RRC.
    Douglas Park, NSW
    If both the window & lock seem to have failed at once, I'd be checking the wiring that runs from the pillar & into the door.
    Thanks all for the suggestions.
    Scott yes it is the lock and window although they went at different times - both were intermittent for a while. Driver side is fine - as it is a ute there are no rear switches/doors/windows to operate.
    So might start with the connection to the door first - what voltage should be coming down the wires to the door lock and window mechanisms? I presume 12 volts?
    Anyone know on a 89 rangie what wire I should test?
    Skiboy
    Feb 2009
    Newborough, VIC
    67.72 MB
    Sounds like a crook earth connection. The earth would be common to both devices.
    Hook up a clean earth and see how it goes.
    2002 D2 4.6L V8 Auto SLS+2" ACE CDL Truetrac(F) Nanocom(V8 only)
