If your 90 has a rover diff at both ends you'll be fine. Did you upgrade axles for the lockers?
JC
i have a 2010 defender 90 ive found out that there is a problem with the rear diffs in some of these modles they come with two difrent types in mine it is the same as the frnt its a landrover diff what is the other diff or is mine the problem diff. i have replaced both my centers with lockers but im jst intrested
thanks![]()
JC
Yep both the same Rover front type as Justin has said.
I ran exactly that setup on my 90 with ARB's front and rear from about 15k km and they were fine.
What diffs are in the 09 puma 130 twin cabs? Do they lend themselves to arb lockers?
