Sorry, I guess it didn't work.Try again later.
Can someone identify this engine pipe for me? I know it's not off a series1.
Thank you
Wal
you were just missing a [ off the front of the command.
Here it is:
Looks like it's off a diesel with side exit manifold..
I thought diesels had 3hole flanges ?
Later ones had 3 hole down manifold . Early er ones had that type..
series 3
Would this pipe fit S2/ s3/ swb and lwb?
It could either fit a diesel or a six-cylinder, I think. The obvious benefit seems to be that, because it swings back in between the chassis rails, you could have a fuel tank under the passenger seat, but you may still be limited to a 10gallon tank. A good find I reckon.
Dan.
69 2A 88" pet4, 68 2B FC pet6, plus other parts cars and pipedream projects.
The early and late series diesel manifolds
The six cyl has the 3 bolt flange at the engine..
