Results 1 to 10 of 11
Thread: Traction Control
    Nov 2005
    Maudsland, QLD
    Lightbulb Traction Control
    I am let to believe that if you update the earlier model rear wheel traction control computer with a MY99 onwards you will get 4 wheel traction control.
    Can anyone confirm or deny this for me???
    2023 Defender 130 D300
    SOLD - 2010 Discovery 4 V8
    SOLD - 2008 Range Rover Vogue L322 TDV8
    SOLD - 2006 Range Rover Sport L320 TDV6
    SOLD - 2002 Range Rover L322 TD6
    SOLD - 2002 Discovery 2 TD5
    SOLD - 1997 Range Rover 4.6 HSE
    SOLD - 1999 Range Rover 4.0 SE
    Mar 2009
    Melton West, Victoria
    I'd be very interested in that answer too
    The brake booster (valve block) is different. Dunno if that matters. Russell Botha (HSE30) may know.
    Don't forget the stronger 4-pin diff in the front with 4-wheel TC.
    May 2008
    I'd be really surprised if you could swap ABS/TC ECU's between pre and post 99 models.
    Pre MY99 models had the Wabco C Type 1 ABS/ETC ECU and MY99-on had the Wabco D Type 1 ECU. The C had a single connector and the D had 3 connectors.
    As Ron suggests, Russell will know for sure.
    Cheers, Paul.
    Mar 2009
    Bexley NSW 2207
    the connections for the valves and earths change positions in the valve block/modulator connector. i have seen the 99 modulator on 95 car, which makes for very interesting braking. as soon as one wheel locks all the brakes come on full no matter what you do with the pedal.
    Quote Originally Posted by Rupert Prior View Post
    This is the problem Barney Roveable was having. I suggested to him that it might be due to the wrong modulator (his '95 had one from a '99 model).
    Nov 2006
    narellan, sydney
    The computer is totally different shape (and plug) too. They are both wabco, but ones a large silver box, and the later is a small black one (similar but not the same as a D2). It would be less hassle and cheaper to throw in a front locker than stuff around with this.
    Andy
    Kingaroy, Cairns and Brisbane
    Hey guys
    I heard a whisper that you can change just the ECU over but then you have to change a whole bunch of other things, which would make it unviable to do so.
    My suggestion: get a few of you together and buy a whole heap of lockers and get a discount, I havent used my TC for ages now, just because at the flick of a switch i get locked.....
    Just a thought
    Ryan
    Feb 2010
    Townsville, QLD
    Does the fitment of lockers (front/rear) have any effect on the traction control of post 99 rangies?? I wouldn't imagine so as it works of wheel speed sensors, but just putting the question out there!
    Keithy
    WasabiPimpNinja Guest
    Quote Originally Posted by Keithy P38 View Post
    Keithy
    I cant speak from experience, but I would assume it would have no effect at all. The TC should only kick in once it has detected one wheel slipping. I'm guessing it does this by measuring the speed of each wheel and applying the ABS brake to the one spinning faster than the other. If you had the locker engaged, both wheels would spin at the same speed, so the TC shouldn't kick in. This should be the case for front/rear slip and left/right slip. Essentially, the computer will think that the diff that is locked always has full traction.
    Or if you're really lucky and have both front and rear locked, the computer will think that the car has full traction at all 4 paws while locked and happily keep delivering power to the lot. When you unlock, the TC system will work as normal.
    Keels.
