The later type press in and out, as mentioned. I can't recall seeing ones like yours - but I upgraded to SIII/Stage 1 axles a long time ago. If yours don't knock out with fairly gentle tapping from a hammer, then they must be threaded in.
Check the diameter of the splined section on the new bolts. If it is larger than the threads on the old bolts, then you can just cut them off and drill them out if they won't unscrew easily.
p.s. - a bit of heat may help them unscrew.
