Thread: Spare tyre cover, bolt on plate type
    fender22 Guest
    Another dumb question, but putting one of those plastic disc spare wheel cover things on. Fits fine and all that but wondering do you just put the spare on, then the plate then bolt that up? Just seems like a lot of pressure on the plastic disc? I was thinking maybe you put the spare wheel on and do up the nuts as normal, then put the plate on with extra nuts to hold the plate on, so all the weight isn't on the plate? Next question, does anyone know what size wheel nuts to buy
    Douglas Park, NSW
    If it's like the Discovery 1 covers, then the wheel is held on with 3 regular nuts & the cover goes over these & is secured with 3 thin nuts.
    There's also plastic washers used under the thin nuts.
    fender22 Guest
    I think you're probably right mate
    Have to find some bloody lock nuts somewhere
    Douglas Park, NSW
    Quote Originally Posted by fender22 View Post
    Nuts as in the 'thin' nuts?
    If so, check with a LR dealer or parts supplier & ask for the one's off a D1.
    Have a look at your carrier though, just to make sure your studs are long enough. I'm not familiar with Defender carriers so check that first.
    fender22 Guest
    They're long enough for about another 1/4" thread, just enough for a lock nut
    Douglas Park, NSW
    The parts you need are:
    Nut MXC7887 - about $10 each from LR
    Washer MXC7335 - about $0.60 each from LR
    Your local dealer can get them in overnight.
    fender22 Guest
    Much appreciated all!
    Feb 2005
    where did you find that plate......its the first one i have ever seen
    Scarborough, QLD
    I think I saw that one on eBay recently. Only one I've ever seen too.
    fender22 Guest
    Ebay, $25 bucks :-)
