Thread: long periods of idling a problem
    fender22 Guest
    Hi. Just put in my second tank of fuel ad averaging between 9.5-10.5l per 100k's. Unbelievable for a big truck. I've checked my speedo with my sat nav and it's all spot on.
    I read somewhere it's detrimental to your engine to idle for too long. I've been driving mine to work and can sit at the lights (are they getting worse) for up to 5 mins. Is that ok?
    The old bloke I bought it off also suggested letting it idle for 30 seconds to let the turbo wind down while the oil was still pumping. I notice if O let it idle for a while before I switch it off you get a little puff of smoke (soot not oil) next time I start it.
    Jul 2003
    5 minutes at a traffic light is normal city driving these days. I really dont think that this will be an issue...half an hour might be.
    I think from memory that the 300 Tdi manual recommended that 10 seconds was all that was needed to let the turbo cool down if you have been working the motor hard. For normal diving just idling to a stand still is sufficient.
    The puff of diesel soot on start up is normal albeit antisocial.
    Mahn England
    Ex 300Tdi Disco:
    Feb 2010
    Stellenbosch, Republic of the Western Cape, RSA
    Quote Originally Posted by fender22 View Post
    You should let ANY turbodiesel idle for at least a minute after a driver, longer than that if you have been driving all day long.
    I would recommend you fit an EGT gauge and then let it idle down to 160C before switching off.
    Feb 2005
    if you back off as you arriving to your destination there is no need to let it sit idle, by the time you pull up, reverse, select neutral or first, apply the handbrake etc i reckon thats enough
    oh the puff of smoke, mine gives a good puff and when i get the opportunity to start her just as an unsuspecting person is walking past i hit the starter......the puff of smoke is normal
    Kingston, Tassie, OZ.
    On a HOT day, working HARD, 30 secs isn't enough. I would do as suggested and fit an EGT gauge, I let mine drop to 200Degrees (Pre turbo), but 160 is better if you can wait that long.
    5 minutes is fine, 30 or 40 is too long.
    The start up puff is normal for a Tdi, Thats one of the the reasons they were out of Europe in the late 90's.
    SO, you can Stop worrying, and ENJOY your new 110.
    JC
    Jan 2009
    Samford
    I find that the 10 second reverse up a slight incline on my driveway before parking sends the EGT upwards to a bit over 200 deg - slight load on low revs. 30 seconds on the turbo timer brings it back down to about 150. The concern with a timer is that you have to leave it in neutral but it's not so much of an issue on flat ground.
    As Naks says, an EGT gauge is a good investment, and easy to fit the probe in the right place on a standard 300Tdi manifold. It's quite interesting to learn what makes for high EGTs. It's not necessarily high revs or quick acceleration but more engine "load".
    Feb 2010
    whats this 110 business, are you going off road?
    Regards Brad
    Mar 2009
    Sarina Beach
    Drive it like you stole it .Put 500 000 km on mine from new and only waited until i took my seatbelt off to shut down. No turbo or intercooler issues ever.My opinion is turbo timers just something else to buy. Even Caterpiller fitters at work recomend no more than 30 sec for their engines.
    Surely the time needed to cool the turbo depends on how you have been driving it in the minute or two before you pull up. I would have thought that if you pulled into a service station on the side of the freeway, that it would need a little bit more time to cool down than if you had just had a couple of goes at parallel parking because you misjudged the first attempt.
    Feb 2010
    Quote Originally Posted by vnx205 View Post
    Indeed!
    Also, a find the landy run more smoothly with addition of 2-stroke oil at 1:200 mix.
