Thread: A Pillar Grab Handle/Gauge Pods
    Feb 2010
    Sutherland Shire, Sydney
    Does anyone know of anyone who manufactures either a grab handle for the A Pillar or a set of gauge pods for the A Pillar in a defender or county? I opted for rock/tree sliders instead of side steps so my Missus would love a grab handle on the passenger side A pillar and I'd like a few gauges on the driver side A pillar.
    Feb 2005
    does the county have a grab handle as part of the dash? or is it too low
    Feb 2010
    Hi Weeds, I should have mentioned that this is a Puma. The Puma has a grab handle as part of the dash (directly in front of the passenger seat), but grabbing it when you;re standing outside the car would pull you across, not up! My 1985 County 110 had a grab handle at the end of the dash which was in a better position for getting in and out of the car but it wouldn't fit in the Puma.
    dmdigital's Avatar
    The door handles are the same distance apart as the screw on the A-pillar cover. Just need a door handle and longer screws. I was all set to do this but SWMBO didn't think it helped her and wanted one above the door. So easy enough to try, justuse one of your door handles.
    Adelaide Hills - SA
    I fitted a grab handle across the top of the door, if that is of any use to you. See thread here: Installing a grab rail/handle in Defender
    Post 14 has a photo of how I did it.
    David
    Logan Village area S.E. QLD
    We have installed a grab handle above the Pass door and one on the drivers
    A piller....mind you our's is a 130, 110's have wires running to the back door
    above the door from memory
    Mrs hh
    Series Landy Rescue
    Our FB Page..
    Dec 2008
    I also installed a grab handle above the passsenger door in my Defender 300tdi - see pic. Made up an aluminium plate that goes under the headlining. The handle screws through the headlining into the plate using the original screws. The handle came from a Holden I believe.
    I made two plates, originally intending to put one on the drivers side, but decided I didn't need it. You're welcome to the plate and a handle if it suits your need.
    Feb 2010
    Thanks for all the great suggestions and for Vin Rouge's generous offer of sending me the spare unit!
    I have a couple of standard grab handles in the garage that I removed when installing the cargo barrier. Unfortunately the spacing of the holes in the handle doesn't match the holes in the A pillar and I'm not prepared to drill any holes in the A pillar because it to structurally too important to mess with, so I'm going to look at the ideas that were posted about installing a bracket and handle above the door. Even if my wife doesn't find it useful for getting into the car she'll certainly use it a lot while we're off road. I currently have an Outback roof console on order so I'll sort out the grab handle whilst installing the console. I'm a bit OCD (owning a defender is a special kind of hell for anyone with OCD tendencies) so I'd have to have a hidden bracket and the matching grab handles throughout the car
    Feb 2010
    Stellenbosch, Republic of the Western Cape, RSA
    Quote Originally Posted by Vin Rouge View Post
    Vin, how did you fasten the aluminium plate in place?
    Dec 2008
    Drilled up through the lip above the door and bolted in the plate. There's already a couple of holes in this piece that take the roof lining studs. They prise out so it's simple to ease down the lining and drill without mucking up anything visible.
