Some "Interesting" Rattles I've had
1 - Jack base in passenger side seat box - Made a dull thud thud similar to yours
2 - Shock absorbers - Not the rubbers - but after 180,000 the original shock absorbers on my td5 110 were making an awful heavy thudding sound over bumps, and that appeared to come from the LHS.
3 - Finally on my new PUMA, the rear exhaust rubber mount keeps sliding out, so eventually the exhaust is pushed up against the chassis. This makes an interesting rumble and thudding sound.
4 - Rear window slides - the original windows in my new PUMA were so loose on the LHS that they rattled when you shut the door or drove on a rough road. A new window frame fixed that but the new one is so badly installed by the dealer that I now realise I should have put up with the rattles....
