10th November 2010, 09:26 AM
Front Hub Breather
Do early Counties have a breather/vent off the front hubs with a breather tube running up to engine bay?
Or is this a feature that some one has added on, as Defers do not have this?
Cheers Pat
10th November 2010, 10:26 AM
My 85 county has the normal diff breathers, but nothing off the hubs.
Sounds like someone has added it on to me.
Steve
10th November 2010, 12:31 PM
Home made addition. I have seen it before. Not a bad idea.
15th November 2010, 10:03 PM
#4
I've always thought it would be a better idea to have a slight positive pressure in each housing/hub assembly, for water crossings etc. Less likely to allow anything past the seals, and you'd soon know when you have an oil leak. Not sure, but I believe Unimogs have this option.
