Results 1 to 10 of 13
Thread: where is the chassis number?
    Guys
    Where is the chassis number on a 2a?
    I thought it was behind the rear left spring hanger but I can't find it..I'm concerned I have painted chassis and covered it up which will be annoying when going to blue slip
    numpty's Avatar
    numpty is offline TopicToaster Silver Subscriber
    Nundle
    Guys
    Should be on the chassis above the rear spring hanger on the left side Lou. Methinks you may have painted over it.
    Numpty
    REMLR No 143
    Hervey Bay, Qld
    ......"Grinder!!!".....
    Feb 2005
    Quote Originally Posted by cucinadio View Post
    er, buff it with a flapper/sanding disc...you don't want to grind the number away altogether
    Hervey Bay, Qld
    yhea sorry, thats what i ment ...
    East-South-East Girt-By-Sea
    1.20 MB
    I usually try with a fine flat file, a points file is ideal and rub lightly checking often.
    On chassis with significant surface rusting you frequently only get parts of numbers but enough to reveal the entire number, helpful if you also have the ID plate on the firewall.
    In your case DB the paint makes it a little more awkward, first look at a narrow angle to see if you can see impressions of the numbers then wire brush first then file in that area.
    Narrogin WA
    What about rubbing the area with emery cloth until the numbers are exposed?
    The numbers themselves can be chased with an engraving tool to clean the paint out if needed and deepen the impression,
    Cheers Charlie
    Bugger never even gave it a thought until a read a post in general today about some guys ease of rego'ing his isuzu.
    I have been out and had a look..its on that actual hanger its self isn't it on the funny shaped almost triangular bit.
    I think I can see it ever so slightly.
    JDNSW's Avatar
    Yes
