Results 1 to 3 of 3
Thread: Best set up for winch kill switch
    Bracken Ridge, Qld
    No I haven’t got a winch yet but am planning to wire it all up so when I do get one there’s a minimal amount of ****ing about – essentially “plug and play”.
    I am wanting to use 2 x carling switches on the dash – one a two way (cable in / out) and one as a “kill” switch – i.e. needs to be on for power to go to the winch.
    I’m setting up a dual battery system as per drivesafes advice (see traxide website for a circuit diagram showing a marine switch which joins the batteries for maximum current availability when winching).
    So how would I go about doing this?
    I assume a relay of some kind is the way to go? Also how do in dash winch control work – on winches is there a plug for these controls or something?
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    WA
    Another option - which saves a lot of time and effort - just get at Tigerz11 winch with wireless remote. Then you can winch from the cab or anywhere.
    I didn't bother fitting a kill switch. I mounted the solenoid box in an out of the way location, and there is a switch on the box to activate or deactivate the wireless controller.
    Oct 2008
    Northern Melb.
    I think kill switches are pretty essential. I have seen a solenoid fused ON, so the winch kept spooling no matter what you did. Luckily they were able to engage the clutch, then it was a mad rush to find a spanner and undo the +ve from the battery.
    I just put a key type battery isolator under the bonnet, so in above situation I would have to pop bonnet and turn key off.
    My Ironman winch also has the wireless controller in addition to a plug in controller. It has been faultless over the last 2 years with intermittent use. VERY handy!!!
