 Originally Posted by
oldrover56
				86 County V8 with the electronic ignition module.
How do I stop ignition hash in the radio???
I thought I knew a bit about suppressing ignition noise, guess not enough.
I have supression capacitors on the coil +, ignition switch, an inline choke on the radio 12v feed, and nice new inductive plug leads.
Antenna ground is clean and ok.
Distributor cap is near new and clean, carbon brush is ok.
I have even looked under the bonnet in the dark for sparks - nothing.
I can't think of anything else to try.
The noise even wipes out the broadcast FM band and the FM cb.
Anyone had this problem and fixed it??
Help, I am sick of hearing my CD's
Thanks,
Terry
 Terry All I can suggest is that the County and Defender ALL have serious earthing issues at one time or another, I would try and fit a decent earth cable from the battery under the seat to a bolt on the seatbox. Also, remove the radio and earth it directly to the bulkhead. Also, the aerial could do with being earthed to the bulkhead, not using the guard.
Hope you find a solution Although with rubbish on the radio here lately I wouldn't mind  'Ultimate Santana' on repeat for a while...
JC
