you're not going to damage anything Lou, it's a breather (& a filter) and can do with a wash out at times
rinse & shake it well when you finish...
... and before you paint it, ensure that it's washed off with turps and allowed to dry
Hello Oh knowledgeable ones
The mushroom looking thing on the top of the 4cyl petrol is it some sort of cleaner or something?
I looks like the one on the side which I thought was also to do with and air filter of some sort.
The reason I ask is I have just taken it off the rocker cover and I would like to just drop it in a bucket of degreaser before painting it black. however when I looked in the little gap on the side it loos like it has some sort of wire mesh of something in it (or perhaps filter material?)...so wanted to make sure I wasn't going to damage anything in there by doing so.
Thank you exactly what I wanted to hear....
I will go wash it now perhaps its just debris caught up in it that I can see.
I dont have any turps here I have just been degreasing, washing with clean water and then wiping down with thinner seems to have been doing the trick
Ahhhhhh ok
thanks again
Actually mine is quite oily is that normal?
 YarnMaster
						YarnMaster
						considering its the breather for the crankcase, yes, thats perfectly normal
Thanks sprint
