Results 1 to 6 of 6
Thread: manual for a Waeco CF-110
    Jun 2010
    Fremantle
    I just bought a Waeco CF-110 secound hand and was wondering if anyone had a manual for one. I want to know if the digital display/setting is for the fridge or freezer compartment?
    Dylan
    03 Disco 2a, TD5, Olso blue, 7 seater, Auto, Chipped, EGR'd, 2"lift, SLS, Dual Batteries, Provent, TM-2 engine saver
    Dalby
    Hello. I have the manual for the older one with the 7 LEDs for temp. Sounds like yours has the digital display.
    The display will be for the freezer section though as the divider is removable to make it one big fridge.
    When the divider is in you set the freezer temp and then let the air bleed through into the fridge. When the divider is out the fridge will still be colder up the freezer end.
    drifter Guest
    Quote Originally Posted by dswatts View Post
    Dylan
    sorry, wrong link
    Jul 2003
    I think I have a PDF manual on the work computer. If I do, I'll post it here tomorrow if no one else does so first.
    I downloaded it from the waeco.co.uk site. It doesn't seem to be opening today...may be someone confused it with the wikileaks site and has closed it down.
    Mahn England
    Ex 300Tdi Disco:
    Dylan, you can borrow mine if you want but they're not that hard to setup. All you need to do is set the cutoff voltage and the temperature and that's about it.
    Being a Waeco dealer I may have a spare one somewhere but if not, swing past my office and scan it if you need to.
    Andrew
    Jul 2003
    Dylan,
    A belated reply.
    You may have taken up Andrews offer in the meantime. If not attached is the Waeco manual for the CF series including the 110.
    Attached Files Attached Files
    Mahn England
    Ex 300Tdi Disco:
