You got dual batteries?
12 + 12 = 24![]()
I have some 24 V lights (should be low current draw as they are only x-mas type lights) that I want to run from a 12v car circuit.
1. Why the hell don;t they use 12v liek everyone else (probably a rhetiorical Q that one).
2) It seems stupid running an inverter to turn 12 v DC to 240 AC and then using the provided transformer to change back to 24V DC. Is there an easier way to convert 12V DC to 24V Dc ?
Alternatively, anyone know where I can get 12 v xmas type lights taht could be run from a vehicle?
P.S. It's a plan to keep Mrs Vlad happy... 'nuff said/
gone
1993 Defender 110 ute "Doris"
1996 Discovery 1
current
12 + 12 = 24![]()
Roger
Hi,
If current consumption is low, you can use a DC-DC converter like this one:
DealExtreme: $11.81 Universal Car Adapter for Laptops
I use it in a regular basis to power my laptop (19V) from the car battery.
Beware:
- it can get really hot if left covered
- it produces lots of RFI interference, so if you have an HF radio onboard, you will notice a great increase in background noise level when plugging this device.
gone
1996 Discovery 1
current
anyone else ?
gone
1996 Discovery 1
current
For a temporary solution:
Get two small 12v SLA batteries from Jaycar and wire them in series to get 24v, then charge them during the day/night depending on when you want the Christmas lights to be on.
Or for a more permanent solution Jaycar also supply dodgy little DC-DC converters that should do the trick, one example is AA-0264 ($28 wholesale).
Please note, I am in no way associated with Jaycar, I just happened to have the Electus cattledog in front of me, that and the fact that RS/Farnell would be far more expensive.
Here are some on ebay
DC 12V to 24V 10A 240W Step-Up Power DC-DC Converter (eBay item 200557065610 end time 20-Jan-11 22:24:46 AEDST) : Industrial
12V to 24V 3A DC-DC Power Converter Module (eBay item 190481362915 end time 17-Jan-11 15:30:47 AEDST) : Industrial
DC 12V to 24V 5A 120W Step-Up Power DC-DC Converter (eBay item 400183740549 end time 26-Jan-11 17:54:40 AEDST) : Industrial
DC to DC Converter 24V to 12V - ABR Sidewinder units (eBay item 390276686035 end time 11-Jan-11 22:27:38 AEDST) : Cars, Bikes, Boats
get some solar powered lights if you want them for a campsite.
Darwin
03 disco 2a td5
93 tdi disco [gone to a better home]
2003 d2a v8 retired hurt
1988 k100rs bmw gone
85 county izuzu [gone to a better home]
69 series 2a [gone to a better home]
series 2a [gunnado]
series 3 [gunnado]
and the tinny
