Results 1 to 3 of 3
Thread: Land Rover Series 2A Sump refit
    Wallydog Guest
    Hi all. When refitting the sump what bolt up procedure is the correct way? is there a torque setting and is there a pattern / procedure to bolt up the sump? Im guessing doing it up too tight is worse than doing it loosely.
    Am i supposed to use Permatex or Hylomar or Loctite product to use on the sump amd gasket before assembly?
    Wallydog
    Dec 2009
    Liverpool, UK
    refit is from rave and TB for revised torque settings. hope this helps.
    Attached Files Attached Files
    Near Seven Hills, Sydney
    Damn. Shonky and I put mine back on last weekend, couldn't find any info like that so just did it. Hope my home made syncork gasket holds
