Results 1 to 10 of 16
Thread: Jack points for highlift jack on defender?
    fender22 Guest
    Bought a high lift jack today and wondered where I would jack the car?
    I used my standard jack on the weekend and that fits into holes in the bull bar or rear bar.
    Under the bullbar slopes upwards / isn't flat so can't use that.
    Obviously no good under the sills. I have mags so jack mates no good.
    How is this done?
    May 2008
    Horsley Park, Sydney
    You can buy / make an adapter for your High lift which uses the existing holes both front and rear.
    IMHO it is not safe to use the high lift jack anywhere else.
    Erich
    austastar's Avatar
    Jul 2009
    Hobart
    Hi,
    my Def 130 ARB bull bar has 2 HL Jack points either side, with re enforced recovery points incorporated in the bottom of the opening.
    The Defender wheels will also accept a strap with 2 hooks, designed to Hi lift from the wheel using the holes in the rim.
    Aussie Expat in NZ
    rovacraft sell an adapter for about $60 that allows you to slit into the round jacking holes.
    Feb 2009
    Adaptor also available from Opposite Lock: Jack Adaptor - Land Rover and Other at Opposite Lock Australia
    KarlB
    Warburton, Victoria
    As above. Get the adaptor. They are awesome
    WA
    As mentioned, make or buy an adaptor.
    Instead (which was much more work!) I made solid steel rock sliders/air tanks/side steps, which are more than strong enough to jack off.
    On the IIA I have jacked off the rear crossmember and rear tow point many times, but it is stronger than a defender, and there is no spare wheel carrier to get in the way.
    Quote Originally Posted by flagg View Post
    Not any more - only via their retailers and probably for much more than $60 now...
    VladTepes's Avatar
    Bracken Ridge, Qld
    Quote Originally Posted by austastar View Post
    Hi,
    My ARB bar hasn't ! Care to share some pics? (Have you got the new Puma friendly arb bar perhaps?)
    The real problem for us 130 types is that we cant get at the rear x-member with a hi-lift due to the tub (or tay) overhang.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    austastar's Avatar
    Jul 2009
    Hobart
    Quote Originally Posted by VladTepes View Post
    Hi,
    Here it is
    Yes the ARB bar is for the Puma.
    Near Seven Hills, Sydney
    Careful with jack adapters, I have a commercial one and it doesn't fit the jacking points in my 85 Conty or Shonky's 96ish Defender. Shaft diameter is too big, only by a mm or so. It was in my vehicle's toolbox when I bought the car so not sure on brand. Test before you buy.
    My Dad's home made jobby fits, its made from a Series axle, some angle iron and lots of weld.
