Usually a small open ended spanner (can't remember the size but I think it's about 9mm) will hold the bottom of the shock whilst you undo/tighten the nut.  If you have rounded this flat sided part of the shock's pin part though vice-grips or pipe wrench are about it.  Some shocks also allow for a hex key to be inserted into the end.
As to how tight: I usually make sure there is a visible amount of thread showing (2 to 4 turns) past the nut.  Not very accurate, but you don't want to over compress the rubbers.  I then check them in a few days.
