17th December 2010, 09:49 AM
Air vent stuck on windscreen position?
I have been getting some condendation in just one spot at the bottom of my windscreen on the drivers side. The reason seems to be that there is air being blown on there from the A/C regardless of where the vents are set.
It has been pretty hot lately and the A/C has been working hard, I'm wondering if somehow with the fan going full blast all the time that one of the vents at the base of the windscreen has been forced out of place a bit and so is stuck in one position. Is this even possible?
I have tried going through all the fan and vent settings in the hope that it would sort itself out through being moved again but no luck.
Has anyone had a similair problem and if so are you able to provide some advice please?
The vehicle is a 2000 Discovery II TD5 Auto.
crl
