Results 1 to 6 of 6
Thread: Rear Propshaft Bush Removal
    Oct 2008
    Johannesburg RSA
    Hi All
    I have purchased a new "donut" and center bush for my Disco rear propshaft.
    How do I remove the old bush and how do I get the new bush in?
    Please, I would appreciate any advice
    grab it with a pair of vice grips and then smack it forwards with a small hammer.
    liberal application of wd40/freezenrelease and twisting it also helps.
    Dec 2009
    Ranelagh, Tasmania
    Pack it full of grease and then select a socket (1/2" 11 or 12 mm from memory) that is a tight fit in the bush. Put a coin over the end of the socket (5c from memory) and then knock the socket in to the bush. The hydraulic action will force the bush out.
    Douglas Park, NSW
    That sounds like the pin removal procedure.
    Oct 2008
    Johannesburg RSA
    I got it out with a hammer and chisel, the most violent thing I have had to do on my disco.
    I used a slide hammer with a single leg attatched and then wedged it with a screw driver in the bush as well, 2 wacks and it was out.
