Fuses, if you haven't already. Do the Hazard lights work?
 Master
						Master
						Folks coming back this morning and indicaters have stopped working, no noise no dash indication nothing. Where should I look first ?
Shouldn't happen with a new car........
 Master
						Master
IIIRC the stop lights are also on the same fuse? Have you been towing a trailer??
JC
 Master
						Master
						Justin I have not been towing mate. And I'll check fuses and hazard lights after I get my 2.5 yr old sun in bed
do you guys know what fuse to check ?
I am mechanically ignorant
 Master
						Master
						My one did the same thing, I just pulled out the relay, tapped it on the windscreen frame, re-installed, problem solvedThe relay is on the inboard side from memory.
 Master
						Master
						Folks as it turned out it was the indicator in the ARB bull bar installed by ARB that was causing it to short out, it was twisted around (globe inside and one little bit of metal cutting into a wire causing a spike) Problem solved. ARB's fault not LR on this occasion !!
