I wouldn't worry about always getting 'genuine coolant'.
As long as you use a 50-50 mix of good anti-freeze & distilled/filtered water, you will be fine.
You can buy the ready-made coolant from auto parts shops, or you can buy the anti-freeze and then dilute it yourself.
I would say use the genuine stuff that you have and once that is used up, just get a good quality anti-freeze and dilute yourself, and keep a bottle of the ready-made in the truck at all times.
Also, it is a good idea to install a Madman-type engine monitoring system, it will warn you of coolant loss way before your Td5 cooks - it is prone to do this within minutes of losing coolant.
 [/IMG]
[/IMG]
