Results 1 to 4 of 4
Thread: RRS 2010 air suspension issues
    Robertdehaan Guest
    I have a new RRS and have noticed warning signs on the dash saying "Normal Hightower only available". If I reset the car, lock and unlock, it goes away for a day. Speed is irrelevant to the warning. I am traveling Australian so access to Land Rover technicians is not easy.
    Any ideas?
    Doesn't sound like any warning message I've heard of? You sure you're reading it right? Or do you mean "High range" only available? That could be a problem with the Transfer Case Module.
    Gordon
    NSW SW Slopes
    'Normal height only available' is a standard message though, which my D4 is showing along with the max speed 50kph msg and beeping. It has a failed compressor so in my case it could be due to the front not rising quickly enough (rise rate is monitored but its not rising at all!) or the pressure is considered insufficient. Either way, the suspension system is unwell.
    Robertdehaan, you need the services of a LR dealership to identify the precise fault and get it repaired under warranty.
    So it's not the RRS gods appealing to the cast of 'Police Academy' then?
    Gordon
