Hi
Some of the first of the series 2's still had 2 Litre motors fitted, check the gearbox serial number to see if it could be the original one, then the placement of the studs at the top of the bell housing, another clue is, the electric SU fuel pump was mounted near the steering column on a bracket mounted to the firewall.
hope this info helps and dosnt hinder you.
Cheers Arthur
					 Whats the chassis number? It may not have originally been a 2.25.  until September 1958 SWB models came with the 2L carried over from the Series I.
 Whats the chassis number? It may not have originally been a 2.25.  until September 1958 SWB models came with the 2L carried over from the Series I.  aside from chassie rebuild a couple of doors not much lucky enough to pick up an old govement landy from inland chassie has no rust but will have to do rear front spring hangers where tanks were fitted pity they took the diesel out but hoping to fit a 200tdi turbo better milage.
