Thread: ABS/TC on a Ford engined Defender?
    Nov 2010
    UK
    My TC does not appear to be working OR it appears I do not know how it should work.
    Please does anyone understand the system and is there any difference in high ratio/low ratio.
    Mike
    might help if you tell us why you think it is not working
    Nov 2010
    UK
    Good point.
    I was stuck in snow recently about 20" deep and engaged diff lock.
    I was in high ratio.
    I had observers and we noted that the nearside front wheel was spinning continuosly and the offside front was turning every second or so.
    This I expected.
    However the rear nearside was spinning freely and the offside rear made no attempt to turn.
    The TC does not appear to be working on the rear axle.
    Mike
    miky Guest
    Assume you are talking 110 here and not a 130?
    Nov 2010
    UK
    Yes its a
    Defender Puma 110 Hard Top County with the optional extra of ABS/TC.
    Mike
