Results 1 to 10 of 12
Thread: Front wheel bearings
    mattg Guest
    Hi all
    I am having a challenge finding the thread on how to rebuild the front hubs on the D2. Can anyone else find it?
    Matt
    May 2003
    On The Road
    AFAIK they are not rebuilt.
    The hubs are sold (quite reasonable $$) as a complete unit.
    Australia
    As Pedro said, no rebuild. Just unbolt and replace. Or do you mean the thread on how to do this?
    Wantirna South, Vic
    Out of interest, has anyone come up with a real REASON why they CAN'T be rebuilt? Apart from the fact that they are not SUPPOSED to be rebuilt as far as LR are concerned, is it actually completely impossible to get the bearings out of the hub and install new ones? Reminds me of the "LR fix" of replacing the entire serpentine belt tensioner for nearly $200 when the bearing in the pulley goes; I separated the pulley and replaced the $6.00 bearing, going strong 5 years later.
    Regards, Will
    LLAMS, FYRLYTS, OL D4 Bar
    mattg Guest
    Quote Originally Posted by winaje View Post
    Thats what I'm looking for, I tought someone had worked out how to get them apart and even had the bearing part numbers.
    Matt
    Do they use the same bearing as the P38A hubs?
    See P38A hub rebuild here: Hub and Wheel Bearing Replacement (Range Rover 4.0/4.6/P38)
    Also read this: http://rangeroverworld.blogspot.com/...-and-hubs.html
    May 2003
    On The Road
    as for the roller--
    sometimes its not the bearing but the roller itself that wears away,,
    but still heaps cheaper from non-dealer places.
    Ellendale Tasmania.
    It's the inner bearing that can't be accessed to be replaced
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    I replaced a rear hub and thought the same so I had a crack at getting the bearing out. No chance! That being said, someone with a commercial oven and the right tools might get it, but not me.
    Commercial oven explanation - heat hub, cool bearing with freon? then extract? Just guessing as not game enough to try.
    I had a hard enough time undoing the hub axle nut (700+Nm). Did end up with a nice 3/4" impact set and rattle gun
    Land Rover - The leader in chasis rust protection with leading edge oil application system.
    2000 Discovery TD5 - ACE. 2" Lift and Bloody big lights
    2016 Discovery D4 SDV6 HSE ARB Bar, lights and winch. Wow
    May 2003
    On The Road
    Quote Originally Posted by eckolsim View Post
    Did end up with a nice 3/4" rattle gun
    IR, ?
