Results 1 to 9 of 9
Thread: Where to put a UHF radio in a Puma..
    Oct 2010
    sydney
    Hi All,
    I hope this topic hasn't already been covered somewhere, but i'm just looking for some advice as to where people have installed their radios in the puma? Photos would be great if you have some.
    Also, where a good place for the antenna? I don't have a bullbar so thinking either somewhere mounted on the grill?
    Thanks in advance.
    Chris
    Jul 2003
    Hi Gitney,
    Do you have a UHF yet?
    The mounting location depends on the UHF you buy or have.
    I bought an ICOM 440 which has all the controls, speaker and display in the hand set. The main unit is fixed to the side of the cubby box on the drivers side.
    The antenna can be gutter mounted which is great for reception but is prone to being knocked by low hanging stuff. Someone here mounted theirs to a metal bracket fixed the top cross member above the radiator on the passengers side. It seemed to be a neat solution. I'll see if I can track down the thread....and here it is:
    http://www.aulro.com/afvb/communicat...efender-2.html
    Mahn England
    Ex 300Tdi Disco:
    austastar's Avatar
    Jul 2009
    Hobart
    Quote Originally Posted by one_iota View Post
    Hi,
    I lifted the cubby and made a new radio mounting bracket that fits under it and is held down by the cubby screws. The wiring is all under the cubby and goes through the floor there to enter the battery box. The radio sits beside the driver, there is only just enough clearance between the cubby and the seat to allow air flow to keep it cool. Mine does get a bit warm.
    My antenna is on the cross bar on the ute tray behind the cab, it is mounted along side a gps receiver permanently housed in a small plastic weather proof box.
    Oct 2010
    sydney
    Thanks Guys,
    I am looking at the Uniden UH7760NB which looks like a similar size to the ICom 440 with all the controls on the hand held part.
    The mount on the radiator bolts looks like the way to go too.
    Thanks for yur help!
    Perspicacious Guest
    I had an idea the other day which I have not yet had a chance to measure up. I am looking at buying a GME TX3340 which is very small (100mm(W) x 85mm(D) x 25mm(H)). My idea was to velcro it to the top of the steering column ie the flat section between the steering wheel and the dash instruments.
    Oct 2007
    Bamaga Qld - The Pointy Bit
    Hi All
    I mounted my gme tx4400 on the dash in the tray in the centre below the gps and rear view mirror
    regards Mark
    Central Coast NSW
    Hey gitney,
    Check out this thread, lots of photo's and ideas
    UHF mounting ideas for 130 puma
    kenleyfred Guest
    This is where I've put mine, also no bullbar so they made a bracket to mount antenna.
    The radio is mounted on the back of the cuddy, a little awkward to turn on and change channel. But it doesn't get much use so live with it okay.
    Luckily it's proven to be a fairly robust radio so far. Whenever it rains water ****es through the sunroof and soaks it.
    Kenley
    Perth W.A.
    Quote Originally Posted by kenleyfred View Post
    Kenley
    Exactly what I was contemplating thanks for that
