Results 1 to 10 of 11
Thread: Under bonnet camping hot water exchange
    Oct 2010
    Carindale, Brisbane, Qld
    I just bought one of these. I was wondering if anyone has any experience fitting these to P38s, and if there was any great advice about where to mount and what to look out for?
    Secondly, I wish to install an additional cig lighter socket under the bonnet to power the shower pump - where is the best point on the fuse box or battery to source power from? anyone done this and got pics?
    Thanks for any info!
    Quote Originally Posted by glenhendry View Post
    I mounted a secondary fuse box on the lip of the mudguard just under the bonnet near the brake booster:
    Oct 2010
    Thanks Ron. Sorry to be dim, but did you source power for that rail of fuses straight from the battery, or from some clever place on the fusebox that is controlled by the ignition switch?
    I am secretly hoping (with all the talk of P38s overheating), that the big heat exchanger will act as an additional small radiator when Brisbane is at its warmest
    PS: I had a XJR13 too, nice bike!
    Jan 2010
    Newcastle NSW
    Dont forget to get a set of O rings if you touch those pipes!
    Oct 2010
    Quote Originally Posted by daljames View Post
    I did my heater core orings 4 weeks ago. They better not need replacing already!!!!
    Directly from the battery via its own main fuse.
    Dec 2008
    Paris, France
    Hey, looks like this thread isn't finish. We need photos and infos about the install?
    Oct 2010
    Quote Originally Posted by 996TURBO View Post
    You are right. Here they are:
    Now: 2005 L322 Vogue 4.4 M62TU (Black)
    Before: 2000 P38A HSE 4.6 - stately capability | 2008 Kluger KX-S | 2004 Forester | 2000 Yamaha XJR1300 | 1993 VR Calais | 1974 HQ Statesman - 308 V8 | HT | HK
    Thanks Glen. What brand of heat exchanger was it?
    Also, still awaiting pix of your XJR1300!
    Oct 2010
    Sorry, I am leaving details out everywhere!
    It is a Helton heat exchanger: Helton camping hot water system
    I will post some pics of the XJR tonight.
