Results 1 to 2 of 2
Thread: Fuse box difficulty/Radio
    Feb 2010
    Had to get itno the fuse box for the 4th time this year to pull out then plug back in fuses for the radio as it keeps going off. This time however it was unsuccessful as radio still doesn't work. Fuses look fine as they have in the past. My issue is accessability to the bloody things.
    I've got large hands but not huge, still can't access the spare fuses as there is wiring looms in the way that make access difficult to say the least. Is there another way without dismantling half the panels surrounding it?
    Might sound like a stupid question, but I buggered around for an hour last night without success.
    I'll book in to LR for the radio as it's under warranty still but is a little frustrating. I've read about the issues with clock loosing time (which mine does) so maybe this can be fixed at the same time. Anyone else had problems with radio faults?
    Cheers Neil.
    Douglas Park, NSW
    Radio faults are fairly common. If a reset doesn't fix it, it may need a software upgrade. This should fix the clock issue too.
