Results 1 to 10 of 26
Thread: D3 V's D4 - Off Road
    St George Dragons Territory, NSW
    Can not recall this question having been asked before so hear goes.
    For those lucky enough to have owned or driven both, the D3 and D4 off road or anyone just wanting to throw in an opinion, is there any difference between the D3 and D4 off road.
    I know there has been many hours spent discussing the merits of 19in rims and tyres and the 2.7TDV6 V's the 3.0TDV6 but putting that aside, what is the consensus, is the D4 any better.
    Regards,
    George
    Gladstone
    I read a review that said the D4 Terrain Response system was better calibrated than the D3 version. But that would be natural outcome for a new model.
    Aug 2008
    Sunshinecoast QLD
    Hi
    I've had both and on the sand the D4 is better (even wth 19'), the sand launch in TR does make a difference, other wise I can't tell any difference.
    Cheers Ken
    Queensland
    I've had both - but D4 has e-diff, D3 didnt; D3 had 18's with ATR's, D4 19's with MTR's; had to tell difference to be honest, both excellent. Big difference for me has been that 600nm of torque. Its very noticeable!
    Melbourne, mostly
    Depends, depends.
    If all else equal and both 2.7s the D4 is just ahead as the Terrain Response is slightly improved, certainly seems a bit smoother.
    If a 3.0 vs 2.7 D3 then the 3.0's engine is much stronger, you can maybe use 2nd low where a 2.7 would use first, and it helps in sand as well. Throttle response is improved too, so better driveability. However, if the 2.7 has 17s and it was one of those really-need-to-air-down-low situations then it'd beat the D4 on 19s.
    Put the e-diff in the D3 and it'd have the advantage over the D4 in most situations.
    Most of the new D4 TR gimmicks are just that. I don't think sand launch is much good as it's one programme for all types of sand, precharge is fairly useless as are the HDC improvements. The TR improvement is in the calibration and refinement of existing programme.
    Biggest difference would be the driver.
    Any reason for asking or just interest?
    Dec 2010
    The one thing that LR could have done to make a really big improvement they didn't do - no offroad height above 50km/hr. To be honest the biggest issue with this is that it starts annoying you at 40km/hr with warning chimes. I could handle the automatic lowering if they cut the alarms
    So it is only opinion of course, but if D4 has the same annoying feature, then it couldn't be any better.
    Oh and I hate that it resets the off road settings after a couple of hours - very annoying when spending a couple of days camping on Moreton.
    I don't understand all of that offroad setting - it seems to have been made to make off roading simpler but it actually made it more complicated in the process.
    Melbourne, mostly
    Ahahaha...mine lets me drive as fast as I want at any height.
    Thanks to LLAMS!!!
    Feb 2010
    Mount Martha
    Had a forum member tell me recently that his D4 2.7 went so much better than his D3 2.7. He was talking on road.
    Not sure if LR made any improvements on the D3 engine????
    Interesting to hear from others.
    Cheers, Craig
    Aug 2008
    Sunshinecoast QLD
    Quote Originally Posted by rmp View Post
    Depends, depends.
    Well, Well
    The sand up here on the sunshine coast (Cooloola, fraser) must be the type of sand it's designed for, cause I,m up the beaches all the time and the D4 handles the soft sand noticeably better, same driver,same air (18lb)
    However different tyres D4..19' ATR, D3 18'..GG AT,
    and motor ..3lt ..2.7lt
    Cheers Ken
    Melbourne, mostly
    Quote Originally Posted by Disco4SE View Post
    Cheers, Craig
    I don't think so, but the handling is slightly improved as is general refinement so the same speed would feel slightly more effortless.
