I fitted the Tekonsha to my D3, the biggest issue was where to mount it, I diddnt want it at my knee which complicated the installation as it ended up where the ashtray was.
The cable run was easy due to the trim that runs along the doors
G
Hi, I just joined this forum and have purchased a RRS to use towing my Off Road CAravan. Has anyonehad trouble fitting a Teconsha Prodigy Brake Controller to this model or the Disco 4, Can it be done by an Auto electrician
Steve
G
Steve,
Search for a thread on trailer brake controller for D4 by Sneigy. He has layed out step by step instructions including photos. I used them for my D4 to install a P3. Absolutely no problems and if you have any handyman tendancies then you will be able to do it.
Cameron
If in doubt, throttle out
MY16 RRS SE SDv6
MY16 Ranger XLT
2008 911 GT2 - dream came true
1976 Escort mk2 - race car
We've got the Teconsha P3 installed on our RRS and so far it has worked a treat. We recently bought a Ultimate Camper and the local auto-electrician in Moruya installed the electrics for us.
All,
Anyone can fit an Electric Trailer Brake unit.
Admittantly it is only 4 wires.
But . . . . . .
It's the modifications that need to be done to get it to work safely & not put the owner at risk & in any Danger
Auto Headlights!!![]()
I fitted one to my D3 and later to the D4. Now Austral in Brisbane claim the air bags are in the way. Bollocks There are no airbags above the brake and accelerator pedal which is where the controller will be screwed. Now its a matter of finding the wires to the pre-installed 12 pin tow plug.
Just a thought .... you might find more relevant info/help in this section of the forum (L405/L494):
http://www.aulro.com/afvb/l405-l494-range-rover/
You'd have an L494 RRS that you are fitting out if it's current year.
I'd guess a couple of owners have done what you're doing.
For example, a thread on UHF antenna mounting:
http://www.aulro.com/afvb/l405-l494-...-vehicles.html
Link to my D4 Build Thread
D3 2005 V8 Petrol
A TowPro fits very neatly to the lower left side of the steering column on my 2014 RRS. Sneigy at MLR did an excellent job of fitting it.
Cheers, Alan
