Results 1 to 10 of 15
Thread: Acceleration *hiccup/hiccough*
    Mar 2009
    Melton West, Victoria
    I've had an intermittent problem for a few months now, which seems to be becoming a more regular or constant problem recently. Under moderate to heavy acceleration it will often hesitate or hiccup, generally just prior to a gear shift up and most noticeable changing from 2nd to 3rd at around 55-60km/h. Revs drop off sharply and return as if I were pumping the pedal up and down - usually only for a second then carries on accelerating. It doesn't do it under light acceleration. It's present on both LPG and petrol
    I've had the faultmate on it and it's returning no fault codes, also logging the engine data isn't turning up anything unusual - except that it's noticing my revs pulsing at the time it occurs. First thoughts were the the MAF is faulty, so replaced that with a known good one. Still does it and with the MAF unplugged the problem is worse. Second thought was one of the myriad of electrical connectors so unplugged/plugged cleaned all that I could find. Still doing it.
    Latest thought is that its my throttle position sensor. I took the TPS off and hooked it up to a multimeter and it appears to give good readings throughout its range. The interesing thing that makes me think it's the TPS is that if I unplug the TPS and go for a little drive (5mins), the engine feels more powerful but has great trouble deciding when to shift - as expected with the shifting. When the TPS is plugged back in, everything seems to be fine again for a week or so - no hesitation. Done this a couple of times over the last few weeks but the hesitation returns eventually.
    Faulty TPS you think or something else still ?
    The pig had similar symptoms one time due to issues with the crank angle sensor. She used to hit a point in the rev range and just drop away/break down (like as in spark break down).
    I'm no mechanic, but it might be worth looking at your crank angle sensor as well.
    Aug 2010
    Pakenham
    I've got a similar problem with that also, along with the hard to start issue in my other post. We need a mechanic!!!!
    Mine was doing the same as you are suggesting, very scary when you go to overtake a semi and it hesitates, even worse when you have another vehicle behind also attempting to overtake. It was intermittent, but could never get it to show fault when at the mechanics. Turns out that it had registered a fault on the computer. Had it replaced, the first one the mechanic got in was faulty before it was even fitted to the car, the second one lasted less than 3 weeks, although it didn't register a fault on the computer. So fingers crossed on the third one that was fitted this week.
    84 Alfetta GTV
    Mar 2009
    Quote Originally Posted by GuyG View Post
    Agreed!
    Had it replaced
    Had the engine ecu replaced?
    Jul 2008
    Geelong Victoria
    Mine does it too! Cures your constipation when it happens at just the wrong time!
    So far I've only noticed it on LPG, probably because I hardly ever run on petrol. Most often after the car has been in overrun, like when accelerating out of a corner after coasting into it.
    It's be great to get a solution for this one.
    Willem
    Quote Originally Posted by Junosi View Post
    Agreed!
    No, just the TPS, but this was in the classic rangie with v8. Can't imagine that that would make any difference though.
    84 Alfetta GTV
    Mar 2009
    Well I've ordered a new TPS from Graeme at Britcar in Melbourne - he's always helpful. TPS is $114 - oddly one of the few parts that doesn't seem to be available via UK eBay or other online shops that I can find.
    I'll let you know how I get on with the new one. If it's still doing it then I guess I'll move on to the crank sensor. Annoyingly it's behaving itself at the moment so I'll have to wait until it's playing up again before swapping in a new tps
    Aug 2010
    Pakenham
    Sounds like i'd have to follows suit. What's the number for Britpart and will he post it out via phone order???
    Mar 2009
    03 9329 5766 for Graeme at 'British Car Components', info@britcar.com.au British Car Components - spares and parts for British cars, Melbourne Victoria, Australia
    I don't know about phone order and postage, I've always picked em up. His prices are usually quite competitive (for Australia), also they are always plus gst.
    Clark
