Results 1 to 8 of 8
Thread: good cheap air compressor for general use.
    Jun 2010
    Rockhampton, Queensland
    Okay,
    I need a good cheap air compressor for pumping tyres & cleaning parts. Doesn't have to be real flash but I guess having a few basic features of the good ones would be nice.
    Any suggestions apart from spending big dollars? looking at something around the $250
    Jul 2010
    pakenham
    have you checked out Bunnings they have some good deals from time to time and some cheap to expensive compressors.. I use a cheapo GMC $99 compressor for most of my jobs. It just runs my air tools and spray guns if i have time to wait for full pressure and is small enough to hide under the bench when not in use..
    Jun 2010
    yeah I was going to get one of those $99 specials but thought maybe for a bit more I could get something a bit bigger, but maybe a $99 one will be okay for basic things
    thanks
    Tassie/Perth
    Drop into a Total Tools store or similar and check out what they have on special. Personally I wouldn't get anything smaller than a 2.5 HP running a belt.
    Chris
    Be warned, you get what you pay for. An el cheapo may easily overheat halfway through pumping up a tyre, that has already taken a half hour to do... If you are talking about a pushbike tyre then OK, but a 4wd tyre?
    Have a look on ebay, you can pick up a really good one there (ARB Air Compressor)
    ARB PORTABLE AIR COMPRESSOR - 12V (eBay item 220742392163 end time 02-Mar-11 13:14:30 AEDST) : Cars, Bikes, Boats
    ARB CKMA12 Air Compressor (eBay item 170589042558 end time 11-Mar-11 12:42:59 AEDST) : Cars, Bikes, Boats
    T-MAX TAIPAN PORTABLE 12V 4WD AIR COMPRESSOR (eBay item 110646429262 end time 10-Mar-11 13:20:55 AEDST) : Cars, Bikes, Boats
    Avoca Beach
    I have a SIP 2.5HP direct drive cheapy.
    I have now had it for about 8 years with no problems except the regulator diaphragm splitting , which I replaced successfully with a bit of inner tube.
    IMHO 2.5 HP is the minimum if you want to use die grinders or even air blowers ( which are very handy to clean radiators), as the compressor will work hard to keep up, and you will have to stop and twiddle your thumbs waiting for pressure sometimes.
    IMHO for home work a cheapy is quite adequate as the cost of repair say a belt drive's motor would IMHO make it cheaper to buy a cheapy and chuck it if it gets compressor or motor problems.
    BUT buy as big a cheapy as you can even if you have to spend $200 or more.
    Regards Philip A
    It'sNotWorthComplaining! Guest
    maybe look at somewhere like the trading post and get a good belt driven second hand compressor? for you money.
    Sure it won't be schmick and glossy, but at least you won't be waiting for it to recharge and have your spray paint dry before you finish the coats. or have hot air blowing out of it.
    we have been down the "not up to it compressors" and you waste too much time with them.
    Jun 2010
    cheers for the info guys,
    I noticed Super Cheap had a 2.5hp 40L hiflo 200L/min free air delivery for $229. They had the same model but 130L/min for $139.
    But yeah, if I could find a good secondhand one cheap I'd get it though.
