Results 1 to 10 of 20
Thread: Common rail diesel problems
    May 2010
    brighton, brisbane
    Just gone thru an old 4wd action mag. , came across an article I had not read regarding common rail diesels [ c.r.d.] their top four 4wd's with c.r.d.issues ; 1. Toyota hilux d4d [1kd-ftv]
    2. Nissan Patrol 3l [zd-30]
    3.Nissan Pathfinder 2.5 l [yd-25]
    4.Toyota Landcruiser v8 [1vd-ftv]
    They gave an example of a 3l. gu iv Patrol with catastrophic failure of the injector pp..Warranty repair was refused, as water in the fuel, causing corrosion, and poor fuel quality , causing scoring in the injector pp.was given as the reason for failure. It took an 190 km. tow in the simpson desert, to get the vehicle to civilisation, and it cost in the vicinity of $10,000 of the owners cash to repair. Now this is not meant to be a dig at any make of vehicle, but they said the common rail engine was developed partly to comply with Europeon emissin standards. The new Defender is on the drawing board, will it face the same problems? Bob
    I’m pretty sure the dinosaurs died out when they stopped gathering food and started having meetings to discuss gathering food
    A bookshop is one of the only pieces of evidence we have that people are still thinking
    Jul 2003
    The Puma engined Defender and indeed all of the other current diesel engined Land Rovers are common rail...it's the only way that a diesel engine can comply with the Euro strandards I guess.
    One or two folks here have had big problems with water in fuel.
    I noticed some exhorbitantly priced water filtration funnels at TJM the other day...probably good insurance for filling up from remote supplies.
    Mahn England
    Ex 300Tdi Disco:
    NSW far north coast
    Quote Originally Posted by bob10 View Post
    [snip]
    Umm, the current Defender is a common rail Euro engine and the previous TD5 engine was a unit injector engine and could have the same issues if fuel quality and filtration wasn't up to scratch.
    In fact when the TD5 was first released Land Rover Australia had quite a number of injector failures due to dirty Australian fuel, and at the time an injector was near enough to $2000 LRA's cost !
    Common rail has taken over from unit injectors as it's a far cheaper system overall and achieves the same end.
    [edit] Mahn beat me !
    May 2010
    brighton, brisbane
    Quote Originally Posted by rick130 View Post
    Thank you, now what is the best way to insure ourselves from a similar incident? [btw. since I bought my d2, I have had to endure no amount of ribbing from my Japanese vehicle owning friends, some good natured, a rare few downright obnoxious, and it is with the utmost calm I say to the rare few.... KARMA! grasshoppers
    Safety Bay
    My Td6 got bad fuel last time I drove back to NSW but a filter change had it going again and it hasn't missed a beat since.The D4D has had a long history of injector trouble but like all things tojo you never hear it from owners. Pat
    Safety Bay
    I'm getting twin saddle tanks on my Puma with a seperate pump and water trap/filter so I can filter the fuel twice.Bad fuel is all too common. Pat
    Jul 2007
    filters and water traps. A centrifugal filter for the fuel would be cool!
    When my RRS was getting its roadworthy, the tester was selling a system - basically water trap and extra fine filter for common rail diesels. He suggested I buy and fit as he had seen a few common rails with issues due to water.
    I declined but am certainly interested if the evidence indicates Aust fuel is an issue. It is a risk management thing.
    simple enough.
    in about 80% of the servos tested in australia the diesel failed to meet even the euro 3 spec for diesel failing on both suspended water and suspended particulate matter.
    most servos were also over the acceptable limit for settled water in the underground tanks.
    and naturally all the military diesel fuel that Ive had tested doesn't meet euro 3 standards (td5) hows the gwagen going to cope (euro 5 standard)
    NSW far north coast
    Garry, I think it's more a case of the storage tanks at some of the servo's in rural areas rather than Oz fuel in general.
    With new storage regulations coming in, at least in NSW it'll reduce the (potential) problems further.
