Thread: transmission wind up
    Dec 2010
    cairns
    still trying to find this slip or shudder sensation in my 110 300 tdi
    so far the forum has been a great help my question is when i was checking prop shaft problems i removed my rear shaft and drove for about 3 or 4 for ks
    on bitumen.
    could this cause wind up cant rember if i had center diff locked there is no shudder or vibration felt through the clutch peddel mainly feel it in reverse
    driving me nuts
    unless youve done something stupid like fitting an auto odds are that its the handbrake binding.
    removing the propshaft pretty much guarantees you cant wind up the transmission.
    mike 90 RR Guest
    Quote Originally Posted by mudder110 View Post
    still trying to find this ... shudder sensation...
    .... mainly feel it in reverse .....
    ....Grab a jack and use it to check for broken engine mounts ... In particular, the gearbox one's
    Mike
    May 2009
    Tatura, Vic
    Dave, I would say in the above statement you could have left out the words
    "pretty much"
    Dave.
    nahh, if you've dropped the back shaft and the handbrakes dragging you can still achieve it...
    you can also do things like call it an automatic... I tell ya, If I was a gearbox and someone called me an auto I'd get wound up.
