Results 1 to 10 of 13
Thread: Stalling with an Auto Transmission
    May 2010
    Brisbane, QLD, Australia
    Hi All,
    Recently I was trying to get myself out of a soft, muddy bog in my D4 3.0L. Front RH wheel was bogged almost down to the belly of the car and the other three wheels were struggling to get traction (stock OEMs).
    I could have aired down, or used my maxtrax but just tried the old jiggle and rev method. I wanted to clear the front wheel a little more so I initiated contingency height by selecting access mode and then manually selecting maximum offroad height once the system went back up automatically. I used rock crawl and managed to wiggle my way out.
    Anyway, during it all.....I stalled the car. Engine cut but no warning lights and restarted with no issue. I don't know much about auto's....but how do they stall the engine? I'm thinking something to do with the TC and ABS.....but then what would I know...LOL!!!!
    Kev.
    Rockylizard Guest
    Quote Originally Posted by Celtoid View Post
    Kev.
    Gday...
    I don't know enuff about LRs and/or D3/4s ... but for the engine to 'stall' without any warning lights coming on tells me it did not stall but 'turned off'. To my thinking, if it stalled then 'normal start-up' warnings lights would have illuminated.
    Therefore, I would think 'something' turned the engine off.
    I look forward to the wisdom and LR experience of others.
    Please explain - is this a way to force the vehicle to go into extended height without waiting for the computer to decide whether it needs it or not?
    May 2010
    Quote Originally Posted by Rockylizard View Post
    Gday...
    Sorry John, wasn't clear enough. It was like any normal start, normal sounds, normal lights.
    I was inferring that if the engine had 'shut down' I would have expected some sort of message. Not that I've actually seen it happen before but there are messages for just about every other thing that occurs...LOL!!!
    Kev.
    May 2010
    Hi Garry,
    Yes I'd read on this site that you can 'fool' the system into giving you that extra few mms, if you are anticipating the need.
    I thought that I'd give it a go, as I was already pretty close to bottoming out.
    Warning comes on and then you select access again. It's a soft touch and up she goes...with another message to say that you are in contingency mode. Then you manually drive as high as you can go.
    Edit: I'll have to check again as I've seen the first warning message appear before when I've selected access mode from off-road height, as I needed to get something heavy into the back. But that was when I was on a hilly track and had no clearance issues. Maybe it only happens in rock crawl mode. I'll have to dig out the User Manual again too.....it's been a while since I read it.
    Kev.
    Sydney, Australia
    It is possible to stall. Done it a couple of times when rolling backwards in forward gear.
    adelaide
    Ive stalled mine tearing up a sand dune, I was more worried about my turbo not having oil presure at this moment , I started it as quick as I could.
    connock
    May 2010
    Thanks guys,
    I was rocking back and forth trying to get the front wheel out of the big hole which was effectively a hill. So there would have been times when I had the transmission in one direction and was actually moving in the other. I know the TC will apply brakes, especially in rock crawl mode...so maybe that's what did it.
    Still don't understand how...as in mechanically, it occurs though....
    Cheers.
    Kev.
    I've stalled my V6 Petrol in Low 1st trying to climb a massive hill. I thought it might have been a combination of the TC trying to brake the wheels and me suddenly closing the throttle when I realised I wasn't going to make it.
    06 SE V6 Discovery 3
    May 2010
    Hi Gary, you've probably tried this already and I meant to get back to you a while ago, after I looked into it.
    If you have any of the off-road modes selected in the Terrain Response System and go from off-road height to access, a warning message comes up.
    If you select access again, the car will then try to make the selection, if it hits anything on the way down, it will pop back up to off-road height and advise you that you now have the extra height setting available, allowing you to use the control to gain more clearance.
    Kev.
    Hi Garry,
    Kev.
