Results 1 to 6 of 6
Thread: Am I a 59' ?
    Apr 2011
    noosa
    Am I a 59' ?
    Hi everone,
    We just got our first resto project two days ago, an 88 series 2a.
    I have been reading other posts and have been looking for some numbers, this is a list of what I found so far.
    Engine block ( near inlet manifold )
    # 525183
    Engine block ( behind water pump )
    # 252313730
    Engine has a brand I think it reads - "DUALLAS" or similar.
    Is this an original LR engine? The glass fuel bowl is marked 'Land Rover'
    Is it a 2.0 ltr?
    Metal plate
    (inside center cockpit)
    Rover Co Ltd
    Solihull England
    LRS 10341
    Ser No 8810341
    Pressed metal Corp Syd.
    # 24309459 C (this number also appears on the QLD rego sticker)
    last regd in 2003. It was regd as a '56 2a ???
    Is this going to be the Chasis number?
    Reading other posts, I am thinking that the 8 digit and suffix number is saying that its a 1959
    The metal plate makes me think its an import not Aust. or ex military.
    Is this a 'rare-ish' model?
    Battery connection.
    What battery would you use here?
    I don't know if this is a ' positive or negative ' earth.
    Any help with these Questions would be great.
    I will get some pics up and show you our rusty project
    The roof is not sitting flat but if somebody wants it, its yours (glass missing)
    there are some door window upper frames (I dont want them either)
    (noosa area)
    Cheers.
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by raskol View Post
    Hi everone,
    # 525183
    # 252313730
    Is it a 2.0 ltr?
    The 252313730 number is almost correct for an SIIa 2.283 litre engine, although I rather suspect that the last character is incorrect. I would suspect the number to be something like 25231373G and would have been first fitted to a vehicle in late 1965 or early 1966. The engine number immediately before was delivered to a customer in January 1966.
    LRS 10341
    Ser No 8810341
    This is the assembly number and is of minimal assistance identifying the vehicle.
    Yes it should be the chassis number.
    No it's a 1966
    No all Land Rovers had that ID plate, irrespective of where they were built
    No its a standard CKD 88 Hard top petrol, delivered to Midway Service Station on 11/1/1966.
    I think if you investigate the engine number you will find it is: 25231372G
    Battery connection.
    I use an N70ZZ although you can use smaller.
    If it was originally -ve earth there should be an ID showing Neg Earth. What it started as may not be the current config.
    Logan Village area S.E. QLD
    here it is
    243 Model: Land Rover, Series IIA
    Body type: Basic or Station wagon
    Wheel base: 88in
    Engine: petrol
    Model years: 1962-1971
    Destination: Completely knocked down (CKD), right-hand drive (RHD)
    09459 Serial number
    C Design: Two significant design modifications
    Suffix used from April 1966 till April 1967
    Mrs hh
    PS Diana beat me to it as always
    Series Landy Rescue
    Our FB Page..
    Lostkiwi Guest
    Hey Raskol welcome
    Can't help you much regarding numbers etc. But somebody on here will no dought pipe up with what you are looking for.
    But in the mean time how about a few pic's to give us all an idea on what you have bought.
    Apr 2011
    noosa
    Thankyou all.
    59', I wasn't even close.
    I am trying get some pics up but that too is confusing me.
    I am about to spray my computer with WD40 and see if that helps
    1.20 MB
    No problem raskol, I was going to suggest that even your 1959 guestimate would be wrong because in the SII era the 4th digit represented year, so your 4 digit would have made a 1960 but the rest of the prefix was also wrong.
    This was redundant when we identified the original allocation record.
    Good luck with your project
