Results 1 to 10 of 12
Thread: Thread size and type
    Sydney SW
    Hi All
    Could somebody be able to help me with the correct thread size for mounting the Instrument Panel on a series 2a. I wish to buy some taps and die nut. I tried my 2BA and 3BA die nuts but screw thread is different. The screws look like original pan head type.
    Mike
    JDNSW's Avatar
    I'm not at home, so I can't check, but I would have thought they were 2BA. If not, they are probably UNF, unlikely but possible BSF.
    Cessnock NSW
    G'day All, If you are referring to the main instrument panel where it is attached to the top rail of the dash/bulkhead, then they are 2BA on S1, S2/2A, also the other panels i.e. military and civvie options, the bottom screws are 2BA with hex/nuts, the top screws are the ones that hold the vent/regulator and they are a type of square thread speed nut, hope that helps, if your dash is different it has been modified by a previous owner cheers Dennis
    East-South-East Girt-By-Sea
    1.20 MB
    2BA gets my vote also, but who is to say what butchery one of the previous owners may have done.
    Brisbane, Inner East.
    Best source in Oz for BA taps, dies, fasteners, is Bruce Gardner, B.S.F. Bolts in Melbourne, 0408 056 255. Also, contact Bruce for BSW, BSF, BSC nuts and bolts. I don't handle BA bits, insufficient demand for an extra supplier.
    Bruce has a large stock of high speed steel BA taps and dies, even some left hand items.
    URSUSMAJOR
    stevep Guest
    Where is a good place to get UNF bolts? I think Canberra is devoid of a place to get older bits & pieces like bolts etc.
    thanks
    Steve
    numpty's Avatar
    numpty is offline TopicToaster Silver Subscriber
    Nundle
    Most reputable bolt and nut suppliers should stock UNF.
    Numpty
    REMLR No 143
    Feb 2009
    Warrimoo, Blue Mountains, NSW
    Quote Originally Posted by stevep View Post
    Try
    Specialty Fasteners
    58 Townsville St, Fyshwick
    thanks
    Steve
    Standard thread in common use. Any fastener dealer has them in multiple grades. Still the most common thread system in use today.
    URSUSMAJOR
    drifter Guest
    What part of Canberra? (North or South?)
    Specialty Fasteners is easier if you are in the south.
    I use Nuts Bolts and Screws in Mitchell. (but I'm in the north)
