Results 1 to 10 of 23
Thread: Governor repairs
    Narre Warren South
    Governor repairs
    The governor on my Series 1 is leaking oil, if I leave the drive belt attached the oil ends up sprayed under the bonnet.
    Since it's trip to Cooma I removed the belt but want to get the home made welder fired up to try it out so fixing the governor is moving up the priority list.....
    Does anyone have any technical details of the governor, especially details of how to strip it down and repair it ? I'm guessing this was a specialised job in it's day so nothing may exist.
    The other alternatives are :-
    Try one of the solutions that rejuvenates seals and see if that works. Although with the seals now over 50years old this is a long-shot.
    Investigate removing the seals from the outside and source & re-fit replacements. This saves dismantling the governor but at this stage I'm not sure how practical it is. It should be fun sourcing the imperial seals so a quick measure up and then sourcing them before ripping the old ones out is the plan.
    Just to add to the problems when I removed the governor to degrease it a year or so ago I found that the pulley is cracked so I need to find another or get one turned up !!
    Does anyone have a governor pulley for a Series 1 they don't need ??
    Picture attached shows the generator & blower (to cool the generator), the red funnel & irrigation hose were the only way to fill the transfer box !
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    JDNSW's Avatar
    I have an old Autopress Manual covering Series 1 and 2. It has a small section on the governor (mainly concerned with installation), which I can probably scan and email to you if you PM your email. It does show that front of the governor has a ball bearing race and a seal. These should be removable by removing the pulley and the front cover, and taking them to a bearing supplier should raise replacements.
    Jul 2009
    S.E.Qld
    I've got an old IBC ESCA catalogue, and the seal is listed as P3281.Any seal shop should be familiar with this number.The L/R part no.is 261573. W.
    PS. I know nothing about governors and this may not be what you're talking about.
    Narre Warren South
    Thanks John (PM sent) and B.S.F. Nut.
    The seal behind the pulley shouldn't be too big a problem but there must be seals where the shaft comes out the side of the body. The worry is that the unit has to be stripped down to get to this area to find out whether it's just an O-ring or a lip seal.
    Any clues as to who would have repaired/serviced these governors back when they were more common.
    Thinking about it I have to visit a diesel specialist later in the week relating to a problem with the wife's car, I'll ask them and see what they have to say.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    From what I remember its similar internally to the works of the CAV pump of the diesel of the era, a diesel shop should be able to sort it for you..
    JDNSW's Avatar
    Quote Originally Posted by gromit View Post
    Colin
    Similar governors were used on petrol engined tractors of the same era Ferguson TEA20?), and some inquiries (starting with tractor dealers or mechanics) should lead to someone (perhaps retired) who can help in most country towns.
    Sep 2006
    Warragul
    Pulley
    If you go to a place that does CNC machining , they will make a new pulley for you . Shop around for a good price . Draw up a good drawing ( takes you back to secondary school days ! ) of the dimensions you need etc, so they can punch the numbers into the machine. It will probably be a "B" section pulley .
    Most of the fees are in setting up the machine . Aluminium may be a option too , because you won't be using it 24/7 .
    Link for article on making pulleys
    http://www.green-trust.org/junkyardp...eltPulleys.pdf
    Mike
    Narre Warren South
    Thanks Guys,
    I'm off to the Lake Goldsmith Steam Rally at the weekend, I'll see if I can find someone who can help.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Narre Warren South
    I found time at the weekend to get the governor on the workbench.
    The seal behind the pulley is the culprit. It's an original leather one which isn't quite holding the oil in (just slows the flow down a bit).
    The input and output shafts don't appear to be leaking so I'll just replace the seal with a modern one and get onto making a replacement pulley.
    I've attached a picture of the seal & the cracked pulley.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    JDNSW's Avatar
    It is probably possible to braze that crack in the pulley - you would need to find someone competent to do it though (The whole pulley would need to be heated evenly), and rebalancing would be a good idea afterwards.
