Results 1 to 4 of 4
Thread: Centre Dash removal - Td5 Defender
    Normanhurst, NSW
    Can anyone help me re the removal of the centre dash panel on a Td5 Defender?
    I've removed the two screws at the bottom but can't see what's holding it at the top. Is it simply a matter of pulling a bit harder or is there a hidden screw/s somewhere?
    Any help/advice appreciated.
    Roger
    Jun 2008
    Heidelberg West, Melbourne
    There's 4 screws holding it in place. Have to remove the top pad to get to them. The tabs that the screws go into are plastic so go easy when doing back up.
    Kelly
    Normanhurst, NSW
    Thanks Kelly - I was hoping that it would be more simple than that.
    Anyway, I've just taken your advice and removed sixteen screws just to get at the three top ones to remove the centre dash panel
    Now to mount the base for my RAM Mount and then try to get all the screws back in their right place.
    Roger
    Oct 2006
    kinross, Perth, WA
    You get much quicker at it once you have done it 15 times
    Steve
