Thread: My progress - A revelation - and probably my issues.. Soot!
    Oct 2006
    kinross, Perth, WA
    Hi Guys
    Just in the process of putting a new intercooler in and revamping the front end, cooling and tidying up a few jobs too while i go... including binning the EGR.
    Well the rad is partially blocked which wont help cooling, the egr system came off without a hassle... not even a sheared bolt!
    I have taken the inlet manifold off to clean it so i can start from fresh... and my god! No joke there is a 6mm layer of sooty gunk on the inside of the manifold.. and its consistent all over the manifold. The freshly cleaned (couple of months ago) temp pressure sensor is caked in soot about 3-4mm thick and the old egr valve has getting close to 15-20mm of soot behind the valve... something makes me think it was leaking!
    Now... is there any way of cleaning the inlet ports without removing the head? and without causing issues later?
    INterestingly the inlet manifold bolts were not tight.. maybe just over hand tight...
    I have also found a freshly started oil in harness, so that will be done too.. and i need to repair the fuel cooler.. as that has a dribble but only on very cold mornings.
    Lets see what else i can find...
    Steve
    Jun 2008
    Shropshire, UK
    You want a V8 Disco, that's what you want....!!
    Oct 2006
    kinross, Perth, WA
    Nah.. you'll be wanting a td5 once you see it go with its monster intercooler.. and it being rechipped...
    ok you may not be able to see behind you... but hey ho... and yes it wont sound like a v8 but the td5 is a distinctive sound!
    Good hol then?
    Steve
    Jun 2008
    Shropshire, UK
    Quote Originally Posted by 5teve View Post
    Been wanting one for a while now, but "not allowed"!
    Good hol then?
    Fantastic mate. Had a great time. Pretty sure the two R's will be gassing all day about it, and arranging a photo viewing at some point!
    Cheers bud.
    Oct 2006
    kinross, Perth, WA
    wow.. just had the inlet manifold cleaned by a company next door to work, bezant autos.. the manifold is silver again.. inside and out.. and i didnt realise it had the lip on the inlet... thats how caked it was! i know its only a simple thing... but i would have been caked as would the surrounding suburbs if i had attempted it!
    All parts should be arriving today!
    Steve
