Problem with Battery/Fridge/DBS
I am going to do my own test, I am having a few battery/fridge lasting problems at the moment, so I am going to see what is causing it, whether it's the battery or batteries, the fridge or the SC40, also the temp that I set the fridge at doesn't seem to being staying where it should, it can rise to 7c from it's setting of 2c that I've set it at, something it's never done unless the battery has been low, I am leaning towards the fridge being the colprit at the moment, but I would like to do the test to find out for sure.
Also my EMS1 is reading the voltage wrong from the batteries, according to the EMS1 when I turn the ignition on and leave it for about 1min (without starting the car) the voltage reading is 11.5/6, which sets off the low voltage alarm in the EMS, I then get my volt meter and test the voltage only to find it's actually 12.4 to 12.7 depending on how long the car has been sitting around and that's both batteries(normally the main starter is the lower of the two if sitting overnight or longer.
Any advice would be good if someone has any for this test I'm about to do.
The first part of the test will be monitoring the temp in the fridge on 240V for 24hrs starting tonight.
No arguing please
Baz.
Cheers Baz.
2007 BMW R1200GS
